DGX-670 Registrations & Playlists
Did a video on how to use registrations and playlists on the DGX-670 if anyone wants to check it out. I found some of the workflow to be a bit bizarre at first, but once I got used to it, they're fast and easy to use (and the playlist feature is awesome).
Many thanks for making the Tutorial and for posting it.
Your video confirms everything I had thought about a DGX well not just that but all Yamaha’s that I have tried, the OS was written by a Klingon.
What a convoluted way of doing what should be a very quick and simple task.
Plus all the button pressing has to lead to RFI (repetitive finger injury).
Scratch one DGX from the bottom of my possibles.
LOL it is a bit "Klingon" in some areas but really not bad once I'm used to it, and the playlists are an awesome add on - way faster and easier than navigating through the banks themselves. Overall out of the 15 or so boards I've owned this is hands down my absolute favorite
