I have the Yamaha 3 pedal unit on the keyboard. I'm learning a song that uses the sustain pedal through the entire 268 measure song. So after a while practicing, the pedal started sticking. Had to shut off the unit and restart, and it would work. But now it sticks immediately on first use.
I suspect it is a hardware issue. I'lll call Yamaha support tomorrow. I thought in the meantime I'd check here.
Anyone have this happen and clear it up?
BTW...I d id try a reset on boot. Didn't help.
