DGX670 Saving Style EDITS without RGT
Lincoln UK
DGX670 Saving Style EDITS without RGT, yes it can be done without having to save a Registration. The Style now no longer has to be associated with the RGT so can be moved anywhere.
Firstly on DGX there is no option to alter OTS’s within a Style. (I use Favorite Voices RGT’s)
My best option is to save my Favorite Voices in Banks of RGT’s…Remembering when saving to Un-Tick Style & Voice then Save MyVoices RGT's.
These Favorite Voices can then be used with any Style you select.
Style Adjusting & Editing Style Parts VOLUMES…PAN…DSP…Part REVOICE etc:
Editing Styles is done as we have previously done on other Yamaha Arrangers apart from OTS’s.
Open MIXER/EQ, to make required Style adjustments, you can listen to your edits.
Now open STYLE CREATOR, TAB to ASSEMBLY select SAVE give Style User name and SAVE.
Close & Reopen Style to Check that your edited Style now contains the adjustments you have made.
Nils Petter Roald
