After last time I list currencies and got some stick I think that this time I have the main currencies listed.
Been into a different Music Store today and rattled a few keys of a batch of digital pianos that they had on display.
Roland Go Piano 88 keys
Quite good sound from a keyboard less than £400, synth type keybed lacking feel.
Kawai ES110
I did not power this up, simply pressing the keys was enough, the action was terrible with clacking all along the keybed. Does not matter what it would sound like the keybed killed any thoughts of buying. The ES110 was£470 but there also was a MP7SE which did feel good but there again it was £1300.
Yamaha P45
Great sound and a good feel to the keybed, pretty good value at only £350, you have to hand it to Yamaha they do produce great piano sounds and affordable kit.
Korg B2
Good piano sounds but the keybed was soft with very little feel, there was only the B2 designation on the keyboard and I could not see the serial plate but I suspect it was the B2N model with the so called light touch action whereas the natural weight action is what is used in the B2, if this was the case I would pass on the B2N model and seek out a B2 which I have played and the action felt OK but not as good as the D1 action. £320 for the B2.
Korg D1
Good piano sounds, very good keybed, downside is that there are no inbuilt speakers so there is additional outlay on to of the £450 cost of the keyboard.
Roland FP10
Great piano sounds which are almost as good as the Yamaha but where the Roland wins is with the keybed, the RH4A action being by far better than any of the others listed and even though the sound of the Yamaha is slightly better the Roland wins by a long way due to its keybed. At £370 is has to be excellent vfm in anyone’s book.
Roland FP30
Similar to the FP10 but slightly larger all around with more onboard sounds and better speakers. The same RH4A keybed (same keybed as the new RD88) so pretty well top notch in my book at this price point and at £470 it is worth the extra cash outlay v the FP10.
Kawai ES110
Yamaha P45
Korg B2
Korg D1
Roland FP10
Roland FP30
