- Joined
- Oct 31, 2013
- Messages
- 2
- Reaction score
- 0
Hey guys,
I am looking for a stand alone keyboard/synth that will do the following and not $3000.00.
1. Piano sounds
2. Synth Sounds
The trick is I want it in mini size. I would like it around 24" wide. Ideally it would have a few small drum pads on it that I could load samples for different sounds. It would also be light enough to mount on my mic stand and 1/4" or XLR outputs......
I play in a cover band and when two guitars are not needed I would like to put stings in the background, or play light piano in the background. If it had the drum pads on it, I could play accent crashes or have a siren programmed in it.
Do they make such as thing?
1. Piano sounds
2. Synth Sounds
