Hi guys bought a used tyros 5 from a dealer recently. I was playing Edelweiss and then suddenly the notes sounded pretty much the same.
Being a novice I don't know if they're giving me the run-around?
Thanks for any help!
Steve
You are playing with the Harmony/Echo button on and an unusual mix of volumes between your R1, R2, R3 voices. This is why it sounds like the three notes are the same. If you were to set the volume of each to 100 you would hear the R1 note playing as usual and the R2 and R3 playing the harmony (which in this case is actually the same note). Again this isn't a fault, it's just the way you've set up the keyboard in this instance.
The guys who sold it me say...
Steve
