I'd like to save a tambourine sound to one of the pads. Is there a way to do this?
There are tambourine waves but no patches that I can see according to the Parameter document. Would it just be a key in a drum set? How can I assign one to the button? What's the exact procedure? Sorry for such a newbie question. Many thanks!! LLIIRC, a pad can be assigned to a key. So first you'd find a tambourine sound you can put on a key, and then you'd assign the pad to play that key. (The DS also lets you put any sound on any key, and set sounds so they don't play directly from the keyboard, so those capabilities might help as well.)
