I will probably get laughed at for asking this, but I just purchased the Yamaha CP4 stage piano to replace and old Yamaha DGX piano. The install went famously, everything seems to work great. I use the USB host to my DAW to record midi. The DAW sees the keyboard and it records midi just fine. It drives any virtual sounds I have just fine (great actually). Now here comes the dumb question...
With my old piano when I set up the daw with a midi track I could hear, and it recorded the piano's internal piano sounds and played them back. With the CP4 it records fine but I hear nothing while recording OR playing back. I assume I will have to run the line outs from the CP4 into my interface, but I am not sure why this worked before w/o doing that. Is there a setting that I am missing that would enable the CP4 sounds to go through the USB?
See I told you it was going to be a dumb question
R
R
