E373/EW310 aux in to headphones or just speakers?
Hi everyone, I just have a quick question about the E373 and EW310. Can you play music from a phone using the aux in and have the sound go through headphones that are connected to the keyboard? The manual just talks about the aux in going to the speakers. I don’t have the keyboards, and I want to make sure before I buy one. Thanks!
My understanding is that any audio which comes out of the built-in speakers gets redirected to the headphones if you've got headphones plugged into the PHONES/OUTPUT jack-- so it shouldn't matter whether that audio is being generated by the keyboard's voices, by a device plugged into the AUX IN jack, or by a device the keyboard is connected to using the USB TO HOST port.
Yes, while I have no experience with the board at hand, what SeaGtGruff descibed is typically how pretty much every keyboard works.... the headphone output exactly mirrors what comes out of whatever main outputs or on-board speakers the board may have. The only exception I've ever come across that work differently are some of the Nords, which were setup to allow you to hear an auxiliary input in your headphones while not sending that signal out to the main outputs.
tc4m
