Never used this keyboard but having a quick look at the manual:
https://usa.yamaha.com/files/download/other_assets/9/1170809/psre463_ew410_en_om_a0.pdf
Page 19 seems to indicate the chord name should show up if you're using auto accompaniment. But I'm assuming if you're not, it won't. Which kind of makes sense when you think about it.
If you have a button labeled Chord, press and hold it until DICT shows on the lcd
There ain't such a button.
The chord name only shows while using auto accompaniment as @CowboyNQ mentioned earlier.
No Col, from the 463. Click on the link I provided and you'll see. Page 19.The info was from a manual for the 453.
I searched for the 433
it is from page 49 of the 453 manual that I posted the info.
Yes, the link shows the 443
