Erratic MIDI transmission with Yamaha P95
Hi there! I am trying to use my Yamaha P95 as a MIDI controller in Windows 10 with Ableton Live and
Everyone Piano via MIDI-USB cable.
When I'm trying to play something on Everyone piano or Ableton Live it seems
I have a huge super delay or latency, difference of many seconds between the moment I touch a
key and the moment it finally sounds. Some notes sounds, others don't. And when they sound they get stuck
as if they had sustain.
In other words, it is as if the transmission of midi data is erratic.
I used a software called MIDI-OX that is used to check the midi transmission between the controller and the computer,
and I confirmed what I describe in the previous paragraph.
Somebody help me please?
There are all sorts of fixes for MIDI latency on Windows systems.
Since no two systems are identical you'll have to rely on Googling "MIDI Latency" and experimenting with proven solutions until you have it under control.
Good luck :)
