Hi all,
Any ideas on how could I change through an external device the sounds I use to my Korg Triton LE when I perform live?
I was thinking that loading a "playlist" with all the sounds I use in a concert, with the right order (which will contain duplicates, as a sound will probably used for more than one songs) in to an external device and then be able to go to the next sound by handling the external device and not my Korg's sound buttons will make my life easier in live performances.
So for example if I have to play 40 songs, I need to load somewhere the 15 sounds that I'm using on these 40 songs - track by track so every time a song ends pressing the "next" button and be ready for the next one. Unfortunately loading and managing sounds playlist in Korg Triton is not that easy while performing.
Any other suggestions/ideas with the same results will be much appreciated
Thanks
Thanks
