Which type of pedal are you using (i.e., Yamaha FC7 or something else)? What specific steps (as described in Chapter 10 of the Reference Manual) are you going through? Do those steps work when you plug the pedal into the Foot Pedal 2 jack?
Hello mr seagtgruff:
thanks for your help. I find the error.
I move some parameter in the function menu that cause the problem. I reset the factory parameters and the pedal1 work properly.
Thanks
