Firmware update
My Yamaha s90xs can't update firmware instead it brings can't downgrade to this version. And the current version is 1.06 which it has can someone please help
Are you trying to go back a version. If so, say that is what you want to do.....
And it is obvious from the message that the software has been built in a way that doesn't allow you to go back in versions. You're stuck at version 1.06.
Now what's the solution for this. as version1.06 is the last version uploaded by Yamaha
crafterofpixels
