I will try that, Thanks TCTOr actually it should be doable by setting up your XF6 to play the drum track with the internal sequencer while using the keys on a different MIDI channel.
Motif XF6, $2400.00 dollars. Cannot play a drum track by itself, while changing back and forth between instruments? Really!
Hopefully I am missing something. So what you are saying is that if I start with a Performance, Say Blues, which has 4 tracks that play together, one of which is a piano, I can switch to an organ sound without the drum beat stopping or having to push multiple buttons to get to a new voice, which does not work when your jamming with someone because it takes too long. I not saying your wrong, I hope you are right.I own a Motif XF6 and I don't understand what you are doing. Even in Performance mode the Motif can play a Drum Track with up to 5 variations and let your switch between 3 other instruments. In Song or Pattern mode you have a drum track and up to 15 additional instruments you can switch between or play at the same time plus an external voice. Read the manual even if its just the Performance Mode.
