Getting sound distortions while playing
I have a Yamaha Tyros 5 keyboard (61nos. keys). When I play, some times loud sound distortions can be heard from speakers.At this time, no performances could be assigned.Some times , an error message appears on the screen saying "Unexpected error!(Sub). Turn the power off and on again.- rxrhmhslncdkb L 284"
Thanks.
Best regards,
Vitha Saman
Sri Lanka
Cell - +94777352038
Welcome.
I would save and backup everything especially user data and undertake a Factory Reset.
If problem persists, service tech as per Don’s advice.
If problem is solved reload user data and test again.
If OK fine, if not service tech.
Good luck.
Welcome.
Good luck.
Thanks for the reply.I will do as instructed.If it fails, I will take the keyboard to the Yamaha agent.
Best regards,
Saman
