Good midi keyboard? Not too expensive?
Germany
Hi, actually I was looking for a cheap one (max 100$/€)
But I think there won't be a good one at this price range.
I already tested 2 Midi keyboards at home. (Alesis q49 and M-Audio Keystation MkII)
Both disappointed me. The velocity is so bad. You have to hit like a freak on the keys to get its full sound. Especially the Keystation's velocity is way too low.
I am lookign for a keyboard where I can hit the keys normally and get 100% volume out of it. It should be sensitive of course too. So don't get me wrong.
Extra buttons are not necessary.
I would be glad to see responses.
Maybe something by Akai, Nektar, or Novation?
Germany
I just checked them. They have all these extra buttons. I don't think I have much space on my desktop.
I also wonder if I would ever use them. I mean all these buttons you have in your DAW as well. And If you make music on your pc, wouldn't you play each instrument alone? Until it is a full song? That was how I started making music last time. I made a simple melody, then added drums and so on.
Also I don't know if I buy a more expansive keyboard if the keyboard velocity will be higher.
I know now what I need. A keyboard with velocity curve.
Germany
Low volume of midi signal - that's my problem
In Kontakt I noticed you can change velocity, and it works well. But I could imagine it could be annoying, having to fix the velocity in every instrument each time I make music. Better would be a keyboard who can alter the velocity intensity, wouldn't it?
Germany
yes that's exactly what I think, it could be annoying. But I am afraid if I purchase a new one i will have the same problem. And then I have to send it back etc....
If I purchase a keyboard that has velocity control, then it will also have all the other additional buttons. That's going to be expansive... And the keyboard will be quite big.
The only MIDI keyboard controller I have personal experience with is the M-Audio Axiom 61-II.
I don't think you're going to find many choices if you want a 49-key controller, but one alternative to the M-Audio Keystation and Alesis Q49 is the Acorn Masterkey 49-- only $79.95 on Amazon with Amazon Prime. I have no experience with Acorn controllers, but it looks like it got some fairly decent reviews.
tc4m
