What are you trying to get from the SK1 to Pro Tools? Are you trying to get MIDI? Or are you trying to get audio? The two are entirely different.Yes Scott..I'm trying to get the internal sounds midi'd over to pro tools....
I'm sending a signal that's being read in pro tools. I just don't know how to assign a sound to the signal
You can not get the keyboard's internal sounds "into" Protools via midi. It is possible to play and control VST instruments (*located in your DAW) by connecting your keyboard and DAW together with midi. But that is done with software instruments loaded into the computer. The internal sounds in the SK1 won't transfer.Yes Scott..I'm trying to get the internal sounds midi'd over to pro tools....
It is impossible, on any device, to ever send sounds via MIDI. That's simply not what MIDI is for.My SK1 is physically connected to my computer via midi cables. I am able to play software instruments on my DAW via the SKI midi,
but I don't know how to send internal sounds via midi to my DAW. Don doesn't seem to think that I can .
Spend about 15 minutes reading this so that you understand what you are dealing with from a MIDI perspective.Hi, newbie here...I'm trying to send out Hammond SK1 programs via midi. I'm stuck trying to figure out external zones.
Any help greatly appreciated.
Bigfeet, I have never heard of any keyboard that has that function. Sorry brother. You're beating a dead horse. Don aka B3maniacDon, so you're sure about that, huh?
