Hello! DGX-620 as controller keys for other KB
So-Cal
SOLVED BELOW!!!!!
Hello the search would NOT let me search by model number it kept excluding it as too short!! they need to fix this!
hi i just picked up a great fun Yamaha with hammer action and waited 88 keys!!! DGX-620 new unsold in box for 200.00 <<< it's is older model and Yamaha says needs to use computer only through usb midi.. ie.. cannot connect to any other midi direct! but i thought i remembered reading some place about a "box" that will do this!!!
i want to use it's KB to control my WK 7500, oh and also use it for some of it's tones!
thnxs
The Y_man
Melbourne, Australia
Unfortunately the search function can be a pain in these forum apps.
You can use google
e.g. Keyboard Forums DGX returns
https://www.keyboardforums.com/threads/need-help-with-sending-midi-back-to-dgx-640-speakers.23500/
https://www.keyboardforums.com/thre...ng-lighter-from-yamaha-dgx-630-ypg-635.23652/
https://www.keyboardforums.com/threads/yamaha-dgx-230-suddenly-lost-power.23430/
https://www.keyboardforums.com/threads/connect-my-dgx-630-to-cubase-5.23332/
In answer to your question, I would say you need to get a MIDI-USB connector like this
https://www.storedj.com.au/products/CME-U2MIDI
and connect the DGX to a computer. You need to then have the computer retransmit the MIDI signal to the WK.
The Y-man
So-Cal
Thank you for the response Y-man
though as both the Yammi and the Casio are usb-usb I have been able to control either one from the other via computer!!! without an adapter to get to the puter... prob is without computer they cannot see each other.. that adapter would not hook to either one on the midi side! i thought i read somewhere, and I thought it was in this forum some place... but could be mistaken about an accessory box or something that would let you hook usb midi keyboards to other midi devices or together!! I'm trying to not have to take a puter along if i use them to play out.. the graded piano keys on the yammi are better action for me.
The Y-man[/quote]
The DGX-620 does not have the DIN midi connectors, and the USB connection on the keyboard is designed only for interface with a computer. External USB adapter cables do not have the capability to convert the data to control another external midi module or keyboard. It seems that the DGX620 also only transmits data on channel 1. I searched the web and found other DGX620 owners who had the same issue, but no one with an adapter that worked. Don
So-Cal
thank you SOLVED!!!!!!
In case anyone else needs the info! I got it at another forum and called the company to Verify
The latest iConnectMIDI has a firmware updated for all the non-standard Yammies!!!!
WhoooHooo!!!
So-Cal
check this out not only will it connect anything, when i sent them a tech question to see if it would they sent me a reply within 5 hours on a weekend!!! WOW talk about support below is the communication...
my e-mail
Hello I have been looking for what your Iconnect is I think?
> I am trying to use my Yamaha DX620 keys to play my Casio WK7500 they are both
> USB midi,, I can with computer but need it out of the loop for live play!
> Is this what your product will do for me?
> Thank you for your time
the response!!!!
Yes, after you update firmware to latest 1.1.0 version, this will work for you, without a computer. Version 1.1.0 adds Yamaha support.
The new firmware and instructions on how to upgrade can be found on our website in downloads section.
Sent from my iPad. Play music with your iPad, iPhone or iPod and your digital piano - check out www.iConnectivity.com.
pretty cool!!!!!!
Similar Threads
