- Joined
- Feb 22, 2021
- Messages
- 6
- Reaction score
- 2
Hi there,
I have a Mark 5 that I purchased new >20 years ago, which until recently worked flawlessly. However, now I find that when I turn it on, all appears normal but no sound comes out - either from the speakers or if you plug in headphones. All lights are operating, I can make any selections I want using the buttons, etc. If I turn the volume slider all the way up I can hear the faint white noise I normally did. Otherwise there is no sound when the keyboard is operated, the Demo button is pushed, etc.
I have already tried the reset methods I've found online with no change. With no success with that, I have largely disassembled the unit and performed a variety of other steps:
Thank you!
- Removed the two metal shields and examined all capacitors for signs of bulging or leakage, damaged ICs, etc. - none found
- Confirmed all fuses are intact
- Unplugged, cleaned with contact cleaner, and reseated all plugs/jacks (under shielded areas and under the keyboard itself)
- Cleaned volume slider pots and confirmed resistance changes with movement of the slide
Thank you!
