Hi to all from a newbie. I do a lot of songwriting and home recordings (guitars, drums, vocals, keyboards), but find keyboard stuff to be the most difficult for recording. I own two Yamaha keyboards, good but not great ones. My keyboard of preference is a Yamaha YPG-235, not that it really matters. When I'm recording anything from either keyboard, I send the output direct from the keyboard into a 24 track Tascam 2488 PortaStudio. Nothing inbetween, just a straight in and out.
First issue: I have difficulty keeping the volume consistent. If I strike a key or chord a little too hard, the volume rises noticeably, like a little "blast" of volume. It's hard to keep a completely steady touch when playing a piece, especially if one hand has to quickly jump several notes or more. I'm probably doing a bad job of describing the issue, but hope that someone out there will understand. Volume inconsistency can be an issue with even a real stringed piano, but nowhere near as severe as with the electronic keyboard. I'm just curious if anyone has experienced this and might have a suggestion or two.
Second, the "Grand Piano" voice always sounds thin and phony to me when I'm recording, so I'm hoping that someone might have found ideal settings (reverb, chorus, compression, eq, or whatever) which produce a more realistic piano sound. I've played with the limited settings in the keyboard itself and also settings available within the Tascam unit, but nothing seems to produce the richness of a real piano. Not even close.
Thanks in advance to anyone who might offer advice.
