Help roland prelude sequencer [song mode]
Hi all this is my first post here.
My name is Luca and i come from Italy.
I just got a Roland Prelude.
I want to use it as an expander of my Korg Triton LE.
If I start the sequencer of the Korg, I listen also plays the notes of Roland.
Inside the menu Roland "Part view" in "Song Mode", where I can reset or change the volume of the 12 tracks of Roland?
In the quoted menu "Part view" I see items like MFX MICRO EDIT MASTER INIT on the first screen, items such as TONE EXPRESS PANPOT etc. in the second, and third volumes of the right and left of the keyb but I do not see how to set the volume of each track.
Help!
Thank you.
The Y_man
Melbourne, Australia
Hi SB,
I had a quick look at the manual.
I think you have to go to each tone that is assigned to the track, and adjust the volume up/down. (Page 38)
MIDI usuallly works of the velocity signal coming from the Triton - so you have to either lower the velocity the triton is sending out, or modify the tone that is being used.
Hope that helps
The Y-man
Uhm...partially resolved. I have to play around Triton commands.
I do not understand why if i lower the volume of a shared tracks via the Triton it decreases the Roland MFX effect volume too.......
