Help with AKX10 measurements,,,? :)
Can someone with the AKX10 help me with some measurements...? :)
I have attached a pic with red lines outlining what I need,
I need the measurement from the bottom of the feet to the bottom lip of the cover - in both the front and back.
As well as from the bottom of the feet to the top of the white keys - the key height.
Any help is greatly appreciated!
If you have a look in the Medeli section at the threads to find a member who has an AKX and send them a PM you may get a response.
I just looked and one member who has one has not been on the forum since last Saturday and if they have active settings they should get the message.
at the back: 2 inches + 1/16" (53 mm)
at the front: 1 inch + 9/16" (4 mm)
key height: 85 mm (I am tired measuring in inches !!!)
Look like you do not have a Medeli AKX10.
Rajitha
