Help with sustain pedal on wk-500
hey guys,
I bought a LoDuca sustain pedal Model #3781 to go with my wk-500.
I have read the instruction manual with the wk-500 and I cant get the pedal to work.
I've tried everything, the pedal doesn't work with either polarity switch.
What setting am I suppose to use on the keyboard, and which way is the polarity switch suppose to be.
Thanks,
Anderson
hey guys,
Thanks,
Anderson
Hi,
I don't know that particular sustainpedal but as far as I know it has to be an on/off model for a Casio.
I could'nt find one where I live for my WK7500 and used an old Yamaha pedal and rewired it a bit.
On your keyboard the setting has to be 'sustain on' or something similar of course.
Hope this helps you.
Dick
P4RKIN5ON
