Hmm, Still worth buying a Yamaha Montage?
phoenix
In order to give myself a wide range of options I am wondering if I should have bought the Yamaha Montage instead of the YC88. I stayed away from the Montage as it is about 7 years old and didn't want to invest in an older board however although I really do love the Yamaha YC I can't see myself using the organ that much. My Roland Fantom 7 is on the way as we speak and I want to buy a Hydrasynth Deluxe and a Summit. For the type of music I can see myself playing, I think that would be a dream set-up.
Yamaha could bring out a new workstation at any moment but on the other hand maybe not! tough call!
No matter what you buy, it will be "old tech" in a year or two.
And "latest tech" will always take 3 to 9 months of backorder.
My advice, make a decision and don't look back.
phoenix
Yeah, you make a very good point. Also even if a new board comes out it's probably not going to be "revolutionary" in any way. I got the Roland coming tomorrow so I am just going to get that up and running which will be fun.
phoenix
Hey Gary, Seeing that I already have a Radial KL8 if I want to add a mixer what setup do you recommend? Would I be plugging the Mixer into the Main in/out of the Radial and am I plugging the boards into the mixer or keeping them going through the Radial?... Many thanks!
I recommend 12 or 16 channels from Mackie or Yamaha. WITH FX and USB soundcard capabilities. Avoid Behringer and off brands at all costs.
Premature channel failure is common on no names and the B word.
At today's prices, should run about $500-$600 plus put aside another hundo or two for cables.
or if you've just sold another kidney, buy one of these. :D
(I hear George Jetson owns one :D :D :D )
EDIT >>> sell the Radial.
phoenix
What do you think about the Yamaha MG12XU - I think I would be looking for a mixer with at least a good EQ and Low/Mid/High gains.
phoenix
Also, Would I be plugging the Mixer into the Main in/out of the Radial and am I plugging the boards into the mixer or keeping them going through the Radial KL8 Thank you!
I've owned the MG16XU for about 6 years how. Not a hint of static.
Proprietary drivers required, though. Be warned Yamaha writes the shittiest DRM drek in their drivers.
Routing is up to you but be advised no matter how you daisy chain the mixers you effectively lose 2 channels.
Not to mention additional power supply cord.
Bring it in for a tradein on a bigger model.
The Soundcraft is cheaper and a well respected brand in the industry.
phoenix
No knobs for Gain or EQ... all done digitally?...
phoenix
Looks really good!
Hi Chris,
A KL-8 is a mixer. Trying to understand why you’d need another one? Have you run out of channels?
phoenix
Hi Chris,
Hey! Yes, and I love it. After having some problems with my overall sound coming out of my boards (nothing drastic) just room acoustics I want some EQ or Gains to fine-tune the sound and don't have any means of doing so. The KL-8 is great and was hoping I could maybe sort my problem out another way.
Rajitha
