If it's your only sample sound, and you want it to sustain without sustaining your organ or piano sounds, just make sure the SUSTPED buttons in your organ and piano sections are disabled (i.e. so that the only section with SUSTPED enabled is the Sample Synth section).Electro 6 I can play/loop a sample designated to one note with my sustain pedal but that also sustains the rest of the keys.
How can I hold a sample with out a hold function thanks.
