Thank you sirYou can't play Yamaha style files in Casio keyboards, nor can you play Casio rhythm files in Yamaha keyboards.
There are programs that can convert one format to the other, but they tend to be expensive.
How to import midi filesIf your Casio will import a MIDI file you could try renaming a Yamaha Style file extension to .mid and try loading it.
I had some small degree of success simply doing this on my Korg arranger.
