Sir i have yamaha A 1000
How to delete keyboards rythm and voice from keyboard amd i want to copy some style and voice through to floppy to keyboard
Plz reply sir
[email address removed by admin]
If you want to send me an email with the file attached, I can see what it looks like, as I've never looked inside a PSR-S970 Backup file before.
I do know that the Backup files on my PSR-E models may or may not contain specific types of data-- such as User Styles and User Songs-- depending on what is actually stored in the keyboard's "system" memory, which differs from its internal storage memory. If the data you're looking for is stored as a file in the internal storage, rather than loaded into the system memory, then it probably isn't being saved as part of the Backup file.
Also, I think some Yamaha models let you choose what to save in a User file, which is a type of backup file and which has a BUP file extension on some models. I'm not experienced with using the PSR-S970 and its features, but if it lets you select which type(s) of data you want to back up, then the BUP file might not contain the data you're looking for.
