- Joined
- Jul 23, 2021
- Messages
- 6
- Reaction score
- 2
I want to control multiple MIDI DIN devices through a computer, and control multiple USB MIDI devices at the same time. This USB3.1 MIDI hub from DOREMiDi looks good, has anyone used it?
You might not be able to connect certain USB-MIDI keyboards to a USB hub, because the manuals of some keyboards stipulate that they can't be connected to a USB hub; they need to be connected directly to a USB host. Check the manuals of any USB-MIDI keyboards you happen to have to see if they say anything related to USB hubs.
Thank you for your suggestion, this is a very good forum, the response is fast, and it helps me a lot!It looks quite lovely and VERRY pricey.
I do well enough with a MIDISport 4x4 and altogether have about 9 or 10 keyboards MIDIed up to my home studio computer.
In practice the only real need for the 4x4 are for certain synths with proprietary USB drivers which almost NEVER work on Linux.
Otherwise, my solution was to add and 4 more USB 3.0 ports to my Linux desktop computer.
The MIDISport is discontinued but Amazon sells a cheap knockoff that is also TOTALLY Linux compliant. I can state from experience that MOTU MIDI Interfaces absolutely DO NOT SUPPORT open source.
Amazon.com: MIDI 4x4 USB MIDI interface: Musical Instruments
Buy MIDI 4x4 USB MIDI interface: Studio Recording Equipment - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Amazon.com: MIDITECH MIDIFACE 4X4 : Musical Instruments
Buy MIDITECH MIDIFACE 4X4: MIDI Interfaces - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
BTW, if you DO need 8x8 MIDI ports (God knows why) Then just buy one of each until you have enough ports.
Avoiding buying two identical units because the device manager will continue to be confused by which device is which.
What MIDI device do you have? I suspect it has a USB connection (not a USB interface) and 5-pin DIN MIDI In and Out connections, and as Gary said, "only one connection to a computer needs to be made, either DIN MIDI or USB." So if you're just looking to connect this one device to your computer, again as Gary said, "that DOREMIDI is massive overkill." You probably need nothing more than a simple USB "printer cable."My MIDI device has a USB interface and a MIDI DIN interface, so I need a hub with USB HOST and MIDI DIN interfaces. This one product meets all my needs.
I was surprised to hear you had 9-10 MIDI keyboards connected to your 4x4 until I saw your diagram and realized you were only using the 4x4 for 4 of your 9-10 devices. I was thinking you must have been using a lot of MIDI Thru!
Thanks for the suggestions from everyone!
