How to adjust main instrument volume when recording
Noticed when recording piano with voice, piano is too loud. How do I lower the piano volume when recording and keep the voice volume high?
I may be wrong but I think that your DGX can record an analogue audio file or a MIDI.
Have you tried recording a MIDI then importing it into a DAW and make the adjustment there.
I did look at the manualand in typical Yamaha style it does not give specifics.
You could also look in the Reference Manual which is a different download.
