How to copy accompaniment or track from one style to another.
I have a Korg Pa4x. any way to copy an accompaniment or track from one style to another?
Thank you.
Dale
Australia.
Welcome.
Yes & No.
How familiar are you with your 4X operating system?
Meanwhile if you search for some software called Pa Manager and research it further you may find that it will assist in what you seek.
I have no experience of using it but am aware of its existance.
Hmmm... Isn't the accompaniment actually determined BY the style, in real time? Maybe I just don't understand the question, but conceptually, I don't see how you could copy an accompaniment from one style to another.
Scott
I see it as two questions in one.
1 The Style
2 The Track
This is what Pa Manager can do
So maybe it can do part of what the Op seeks.
How I used to create a new Style for a specific song was to copy a donor style to a userbank and then customise it to suit.
An alternative is to create a Style from scratch and there is a great video online by Kris Nicholson on how he does just this.
Not related to the thread, more info for the Op.
Do create a Backup file before you do any further actions.
Also create a Save All file ( saves user data in an easier form ).
There is a bug in the 4X BKP file creation process which has yet to be resolved. It relates only to large file sizes and leads to corrupt data. Hence the Save All is an essential file to create on a regular basis.
