How to create midi B3 setup
Do you mean that you want to install a virtual B3 instrument on a computer, laptop, or tablet and then play it with a MIDI keyboard controller, or do you mean something else?
Hi there, yeah more or less. Looking at GSi VB3 ii. Install that on an iMac and trigger with a couple of midi controllers. I already have an NP30 and an old GEM WS2 workstation for the 2 manuals which I think will do the job. Bass pedals are proving to be an issue
Failing that I've heard I should be able to connect a Leslie ( I have a 147 with my old Hammond) to my VK6 and bin the Sharma cabinet.
It all boils down to not really having room for my Hammond as it's all Flight cased and a bit ugly looking
Was just wondering if anyone else had chosen a different route ?
