According to Casio's web site, it has an SD slot in the front, above the keyboard where they show the icons for the drum kit, toward the right speaker:
http://www.casio-intl.com/in/en/emi/indiankeyboard/ctk810in/
But on page E-6 of the manual it shows the SD slot as being on the back, to the left of the USB port.
On page E-59 of the manual it says to use an SD or SDHC card that's no larger than 32GB.
On page E-74 of the manual it says the following about the "Err Format" message:
Cause: 1. The format of the memory card is not compatible with this Digital Keyboard.
Action: 1. Format the memory card (page E-60).
Cause: 2. The memory card is damaged.
Action: 2. Use a different memory card.
Cause: 3. You are trying to use an SDXC card.
Action: 3. SDXC cards are not supported. Use an SD or SDHC memory card.
So assuming you're using the correct type and size of SD or SDHC card, the instructions for formatting the card are on page E-60 of the manual.
I've just skimmed thru the entire manual. That thing doesn't support SD Cards or any kind of removable storage. Where the hell are you plugging the card into?
Actually on all Casios I've seen so far, formatting the card in the keyboard creates the necessary MUSICDAT folder automagically. I'd imagine they followed standard practice designing this one as well.
But the brand of SD Card can make a big difference.
There are programs that will reformat a Sandisk Card and remove the crap partition for you. Perhaps run one of those and then format it in the keyboard again. Use the U3 Removal Utility First if it applies to your card.
http://kb.sandisk.com/app/answers/detail/a_id/2550/~/removing/uninstalling-u3-launchpad-on-a-pc
https://www.sdcard.org/downloads/formatter_4/eula_windows/
If it still doesn't work after that then try a cheap no name SD card and see if that works instead.
Sometimes a certain brand of card is simply incompatible with a certain model of keyboard.
I'd suggest trying a different make and model of SD Card just to see if that's the problem.
My nephew's WK-110 doesn't have an SD card slot, so I don't have any way to try using an SD card myself-- but I'll take a closer look at the CTK-810IN manual and see if says anything that might be helpful. What is the exact message that you're getting now-- is it still "Err Format," or something else?
The suggestion about trying a different brand might do the trick. I have some SanDisk USB thumb drives that came with some software pre-installed on them, and it seems to be impossible to format them in a way that removes that software-- when I reformat the thumb drive and then stick it in the computer, the computer shows *two* drive letters for the thumb drive instead of only one! I don't know if your SanDisk SD card is similar in that respect, but if it is then this might be causing a problem for the Casio-- in which case using a different brand may help.
I know that Yamaha actually has documents that list which USB thumb drives are confirmed to be compatible with its keyboards. I don't know if Casio has similar documents for SD cards.
One other thought-- when you created the "MUSICDAT" folder on the card, how did you type it in? I'm wondering if it needs to be all caps-- and don't put a space between "MUSIC" and "DAT."
