How to record a midi track to my dgx 660 from my computer
Usually there's a setting in the menus somewhere to enable MIDI OUT and/or USB OUT.
You'll probably find it under the MIDI options or the System Options in your menus.
Double check with your manuals if you can't find it easily.
I suspect that the DGX models, like the PSR-E models, don't let you record incoming MIDI data. Instead, what you will most likely need to do is send the keyboard's MIDI data to your computer, along with the MIDI data coming from your other device, so you can record them all together in a DAW. This will give you greater flexibility anyway, because a DAW's editing features will be much more comprehensive and versatile than what the DGX has.
