How to remove a key on PC3x?
Does someone know how to remove the keys on a PC3x? These are not like any I find examples of online.
Thanks.
Youtube is your friend.
Remember to photograph or video record every step of the disassembly and mark the polarity of any connectors you remove before you start ripping it apart.
If you need any more help post your questions over at
http://forums.godlike.com.au/
These guys can give you solid step by step advice.
I found out how. It snaps in from the top, so to remove, retract the lip on the clip using a small screwdriver to press it forward while lifting on the back of the key.
Yes. I saw those videos, and the keys are not held in the same way on the PC3x I have.
