How to reset Yamaha MM6 Keyboard to Factory defaults?
I just bought a used yamaha mm6 keyboard and i want to restore it to factory default settings because i don't know how much the previous owners mess with the settings.
If anyone know how, please can you post step by step procedure, Thanks a lot.
I figure it out lol i end up calling yamaha support and it was simply by turning OFF the keyboard, then Hold the last key chord of the keyboard to the right, then turn the keyboard ON again while holding the last key of the keyboard and on the Screen it will say Backup Clearing and wait until the keyboard shows Power Grand. :)
If this was helpful for anyone else that was trying to do the same thing, please post a reply.
Rajitha
