- Joined
- Oct 14, 2010
- Messages
- 1
- Reaction score
- 0
...not to mention the new Authorization Manager! No more copying and pasting long authorization codes or jumping between web pages and the old wizard.
http://www.ikmultimedia.com/sampletankfree
SampleTank FREE is a full-featured version of SampleTank 2.5, with a 500 MB specially selected samples library. Now you can experience the full power and flexibility of the industry's leading sound sample engine for FREE and build your compositions to perfection.
No longer limited - Multiple instances that opens ALL SampleTank format sounds, import functionality, and the ability to create your own user presets.
• Over 500 MB samples for over 200 sounds included 16 part multitimbral with easy layerable/mixable parts
• 3 synth engines:
• The most powerful multi-effects section in a virtual instrument:
• 33 built-in DSP effects derived from award winning audio processors like T-RackS and AmpliTube
• Part and Master Loop Sync
• Can be expanded with: SampleTank 2.5 L and XL sounds and any "Powered by SampleTank" sound modules including Miroslav Philharmonik, Sonik Synth 2, SampleMoog, SampleTron
• Can be expanded with any Xpansion Tank 2 sounds
• Imports WAV, AIFF, SDII, AKAI S-1000/3000, SAMPLECELL
• Available both as a standalone application as well as a plug-in
• VST, RTAS, and AU on Mac OS X/Windows
• 3 synth engines:
- - STRETCH™ (formant preserving pitch-shift/time-stretch)
- Polyphonic Pitch-Shift/Time-Stretch (PS/TS)
- Resampling
- - 5 insert effects per Part
- 5 Send effects
- Master effects
