Imperial March Midi Sequence
WI USA
This is my first attempt at using the orchestra sound set on the integra, I found a midi file that had potential and began swapping out patches and mixing Natrual acoustic and PCM voices.. I just had to try the Imperial March cool stuff By John WIlliams! ;)
WI USA
Not bad, but the horn section needs some punching up to give them more presence.
Oops yeah i had the EQ on when i was mixng and have the mid range bumped up a bit for playback only, i turned the EQ off and horns went poof into the weeds lol, thanks fot the input!
