iPad and Korg PA600?
Can I save my songlist along with the songs' style settings on my iPad and make song selections from there, instead of from the small screen on the Korg PA600?
If so, what software or hardware do I need?
If not, what comparably-priced arranger keyboard would let me do that?
Thanks in advance.
I have heard that the app called Songbook+ will do this. Maybe check out the lite (free) version to check compatibility.
Thanks, Reuben. I've had some advice that the PA600 should be able to work with an app that sends "program change" messages like the ones I described. I will take your suggestion--I'm also looking into an app called Set List Maker.
I have been using Songbook+for years. First with PA1x, now with PA3x. It has a code box where you put in the Korg songbook number. Also a spot for program change messages.
OnSong is another one, less expensive, but to me, not as user friendly.
Riff1117
