I know this is an old post but to answer the question, If your keyboard has a performance mode, that's where you can have separate settings like that. use the same sound for 2 parts but have only one with a bend will do what you want and will sound great on a lot of stuff. If you are using an older analog synth you might have to add another keyboard and just bend one.those cliches where you strike 2 string, but bend only one.
For example, you do an A and a G bending to an A. That creates a very unique sound.
is it possible live?
is it possible at least for recording purpose?
forgot to add, if you use 2 strings patches and only bend one, you can 'slur' the sound. sounds real good. i also like the other post of using after touch. haven't tried that yet. but if you want that classic guitar 2 note thing, you'll like how i do it. cuz thats why i do it.I know this is an old post but to answer the question, If your keyboard has a performance mode, that's where you can have separate settings like that. use the same sound for 2 parts but have only one with a bend will do what you want and will sound great on a lot of stuff. If you are using an older analog synth you might have to add another keyboard and just bend one.
