hi to all!
i bought an akx10 and loving it!
i have a korg kronos and yamaha modx8 where there is a function called smooth transition, changing from 1 combi or instrument patch theres no cut-off from instrument to the next set of instruments.
question, does akx10 have this?
also, is there a sustain preference somewhere in the menu? when i use the sustain , whether its strings, brasses, woodwinds, piano , it does not sustain that long. it cuts off shorter than it should
any help will do.
thanks so much in advance!
regards from houston texas!
any help will do.
