Joystick
Egypt
Hello All,
I am facing an issue with A5000 joystick, it does not return to 0 position modulation if I move it slowly, but if I released it, it will return to 0 position vertically, the same issue is described in that video:
there is also a comment about solution to that problem using joystick calibration,
Have you faced this issue and how did you fix it?
can someone describe the detailed steps to do the joystick calibration?
Tampa Bay Area, Florida
Hello All,
Did you try zooming in to the 3rd picture of the Amazon review? It details how to calibrate the joystick.
Egypt
Thanks a lot Gourockian, yes, I followed these steps, but I do not know if I have to stop moving the joystick when I hear the sound in each direction or shall I move to far left, far right, top and bottom positions.
Also the issue still there after following these steps and stop moving the joystick once I hear the sound.
The way I read it, you move the joystick to the left only until you hear the C sine wave (minimum movement) them move it to the right (maximum) until you hear the D3 sine wave, then release it to get the #3 sound. Next, you move it the minimum downwards till you get the F3 sound then maximum upwards to get the G sound. Then release it again to get the C4 sine wave sound. You should then see either "OK" or "NG" on the screen - if "NG", I would repeat the whole process untill you see "OK".
Failing that, hopefully someone on the forum with the same model can offer more help.
Similar Threads
crafterofpixels
