true transpose or just a pitch change but not exactly 1/2 step related? if it is truly 1/2 step, full step then you might have a sticky transpose switch that is randomly engaging. if the pitch is drifting but not exactly 1/2 step then it could be a bad pitch wheel. try flicking the pitch wheel when it does it and see if it goes back to normal pitch, if it does then that is your likely culprit.
Try a factory reset. Note any user programs/data will be deleted. Save the user programs/data somewhere so that they can be reloaded after the factory reset:Hiya Dave. When it randomly transpose it tends to shift key by a whole tone. The keyboard is also set a semitone down even thought I have the master at 0 which is strange. A battery low light is also coming on-cud this be the little battery that is responsible for memory and maybe Themis is causing the changing key issue? Thanks so much.
