Key sensibility lost
Hello all,
I'm having an issue with my digital keyboard yamaha psr-e343 and every D and Ab makes the loudest sound, or simply doesn't sound, as it had lost the sensibility.
Sometimes when I start it up, it works perfectly fine.
I also recently bought a sustain pedal, but I don't know if that affects my piano.
Thanks
Might have a loose/bad connector in the keyboard. Recommend that you remove, clean and reseat the keybed connectors first. Could be that simple.
tc4m
