Keyboard Lights Neon Blue
Neon blue LED musical keyboard
Upper and lower keys all light up according to keys pressed
Can turn off LED’s for daytime play
Controlled by midi software connected to a computer or smart phone or independently no PC required
Option to dim LED’s
The ability to play in a dark environment producing appealing effects
Cameras to some degree give a small differential visual appearance and the glow looks more attractive through the naked eye
Everyone’s views on this post will be different that’s what makes us all unique
I've added a battery-powered strip of LEDs (dimmable, and various color choices) to my Hammond "B3 case" for my Hammond SK Pro 73 for use on dark stages -- see the images below -- but keys that light up?
My first thoughts...
* How's the keybed and the action? (Most important!)
* How's the sound? (Also important! Or is it MIDI with virtual VSTs?)
* What happens when the LEDs on the most-used keys fail? (Important some day)
For fast leads or soloing, I also think I'd want to know "where G3 is" before I hit it -- and not when/after it's played...
To me, the lighting or the lighting effects (those lit-up keys) is secondary to the sounds & music I'm playing. If it helps -- great! -- but it's not the primary output.
Old No7
Akcel
