- Joined
- Jun 26, 2015
- Messages
- 25
- Reaction score
- 1
Didn't see anything like this so thought it might be nice to have. The ones I review all have what I consider "basics" like weighted keys, split keyboard ability, a pitch bend wheel etc.
CASIO 150
Cost: about $500
Voices: 18
Polyphony: 128
Recording tracks: 2
General impression: this thing specs out most impressively for it's cost. The sound (the piano sound, the others) is also fine. But the speakers are somewhat inferior (kind of weak) and IMO the key action is poor, unless you like very loose and very loud keys (make noise when hit). But as with all of these I advise you to try one because opinions are only that and if you can live with the speakers and key action, might be the one for you.
CASIO 350
Cost: about $700
Voices: about 250
Polyphony: 128
Recording tracks: 17
General impression: this thing specs out most impressively for it's cost too, with a whopping 17 track sequencer and tons of voices. For the rest, see the 150 above; same deal. Basically if you want the added tracks and voices, get this; if that doesn't matter, save your $ and get the 150.
YAMAHA 650
Cost: about $800
Voices: about 150
Polyphony: 128
Recording tracks: 6
General impression: while it's somewhat less on tracks and voices, the Yamaha has better sound and key action than the Casio. A fine overall keyboard IMO other than that. Again, your prefs and tastes comes into play, so you'd really need to try one.
KORG KROSS
Cost: about $1000
Voices: about 150 (at least - they say less but I played it, there are more, didn't add me up though)
Polyphony: 80
Recording tracks: 16
General impression: not as much bang for the buck as the others in terms of just specs, but IMO it more than makes up for it with far better action on the keys. However it uses an SD card to save off music (? why they didn't use USB I'll never know) and doesn't have built-in speakers, which means expect to pay at least another $100+ to cover that. Course the good news there is even cheap external speakers will sound far better than the built-in ones.
CASIO 150
Cost: about $500
Voices: 18
Polyphony: 128
Recording tracks: 2
CASIO 350
Cost: about $700
Voices: about 250
Polyphony: 128
YAMAHA 650
Cost: about $800
Voices: about 150
Polyphony: 128
Recording tracks: 6
KORG KROSS
Cost: about $1000
Polyphony: 80
