Hi All,
Can anyone help me to find a keyboard that fits my uncommon necessities?
I´m not a keyboard player (I play bass) but once I compose my songs alone, keyboard helps me to develop melodies for other instruments. Nowadays I use a MIDI Controller to do that but I´d like to be more independent of the laptop.
So, my main requirements are:
I did a research and Casio SA-76 would be the ideal one IF it records and could be used as MIDI controller. :-/
What do you recommend me?
Thanks
- Could be used as MIDI controller (and Record MIDI to transfer to computer)
- Small and light (Casio SA-76 is a good example)
- Has speakers (so I can play without plugin phones or amps)
- Very Cheap (Casio SA-76 is a good example again but let´s consider a budget around 100€)
Thanks
