keyboard style
If it is what I think it is then it is an App that is a virtual Arranger.
There are a few Apps for different platforms that do the same function.
We could be more specific if you gave us details of who the Developer of the App is.
this app ok.
I'm not sure what you're asking about that app, but from its description in the Google store it seems to come with 256 Yamaha styles and lets you load new Yamaha style files. I hope they aren't actual unaltered styles exported from one or more of Yamaha's keyboards, or Yamaha might take exception to their copyrighted styles being freely distributed with the app.
As Michaels states, it looks like you load either a Yamaha or Korg style file and it uses the inbuilt sounds to generate the accompanyment.
Interesting app, the company also seem to produce a DAW like app as well
i want to play this file use in androide.
how do?
I think you'll need to contact the app developer for information on how the app works, unless someone else here happens to have an Android device and happens to be familiar with that particular app.
It should therefore be a case of putting the Style files on your device and then loading one from within the App.
If you cannot then there may be a few reasons why but my guess would be that it is not of the correct format ie SF2.
Do the Styles that are included within the App function?
