Keys not working... Casio CDP 220 R
The first 10/16 keys on the left side of my keyboard do not play...? I recently had the unit apart to repair a key weight on the opposite end of the board so I might have messed something up putting it back together but there is a single plug from the keyboard to the motherboard. Thoughts?
Yep, I think you said it.
I would take it apart again and check all connections and possible damage that you might have done.
If you see anything untoward then posting an image may help
Midiaccordion
