Kontakt 6 (sampler platform)
Native Instruments has been around for some time, leading the music software industry with sample profiles and effects. In order to best use the software a platform had to be developed, similar to requiring a Mac or Windows OS in order to run a word processor, for example. Similarly, Native Instruments developed Kontakt in order to run in-house, licensed and third-party samplers. For those unaware of what a sample is, the most obvious would be traditional instruments, such as piano, bass, orchestra strings, etc., all of which sounds are controlled by a ‘controller,’ e.g., piano keyboard or MIDI guitar, for instance. Consequently, you can take a synth, piano or guitar and have it sound like something completely different.
Originally, I investigated the Kontakt platform as I wanted to work with a sampler program called Dystopian Guitars, a third-party product developed by PulseSetter Sounds (I did a review with demos on this, as well). Kontakt was required to host Dystopian Guitars, and both worked seamlessly together – no locking up, no pausing or glitches. Moreover, Kontakt comes with its own sample library and has become the industry standard with the biggest selection of samples from Native Instruments and other sample designers – in other words, if you want variety in choosing your samples, you’re going to have the largest selection with Kontakt versus any other platform. The accompanying demo includes some sample sounds that come with Kontakt, as well as a few from Dystopian Guitars.
The Kontakt program does allow a person to create his or her instruments, for those with the determination to do so. Being new to the platform, that certainly is over my head for now, but it will be an interesting project down the road. Regardless, Kontakt is very easy to use. It can be a stand-alone platform, so that you can open the program and play samples live through a computer, or it can be integrated into a DAW for recording purposes (you need to create a new soft-synth track and add Kontakt to the effects bin). Once open, you simply select what library you want (e.g., orchestra instruments) and what instrument you want. With your computer or DAW set up properly (e.g., select what instrument will control the sounds, e.g., piano keyboard), you then replicate the chosen sampled instrument, e.g., cello, violin string section, etc. In a nutshell, that is it, for both live play or if recording an instrument in your DAW, thereby developing soundscapes for movies, gaming or jamming backing tracks.
You then can increase the complexity of samples, merely by adding layers onto the Kontakt platform, e.g., merging a bass guitar with a pad and perhaps a kick drum – all controlled and timed perfectly by the same notes being played on the controller. This certainly is a time saver (presuming they all play the same notes), but allows you to create a wall-of-sound for those massive Devon Townsend backing tracks. Both the ease of use and flexibility of Kontakt are key aspects to why this program is a must.
Now, the latest version of Kontakt (being version 6 at the time of writing this) has some new features from the previous versions. They include a wavetable synthesis module, new instruments, new modulation effects (choral, flair and phasis), the ability to drag-and-drop your own instruments, enhanced effects and creator tools in the new standalone application. For those familiar with Kontakt, this brief overview and included demo obviously are to the point, but for new users who may be of a different musical background, e.g., a guitar player familiar with hardware (pedals and amps), like myself, the use of Kontakt and what it offers opens a door to a whole new world of composition possibilities. In that regard, the accompanying demo includes basic operation of Kontakt, and how it works within a DAW, but also its use in replacing or substituting instruments in an already created backing track (in this instance, PG Music’s Band-in-a-Box). As stated, Kontakt does include a variety of instruments, some traditional (e.g., guitar, bass, piano, strings, etc.), but also some that offer hundreds of sound variations (e.g., Ethereal Earth). Those will keep anyone busy for a while, but then there are hundreds of unusual, unique and fantastic sounding libraries available that puts an entirely different spin on the term Gear Acquisition Syndrome.
I use NI Guitar-Rig 5 a lot with my synthesizers to produce Guitar-like sounds (and it works well). They (NI) make beautiful software
I do have that software. I nearly always use my hardware, as I develop and practice using the Band-in-a-Box program, and so... I tend to stick with that stuff. However, NI is a great company!
Landgraaf
Yes it is. I also have on old but fine Line 6 pod that I take out for live performance, but the Guitar-Rig is more flexible/useful for studio because it does not take any extra space.
